Dear ALl Community,
I have a question about my project in all. I am using the Redbot, (Arduino)
to form an ADC. The guitar picks in my headset, will pick up the neuron signal,
and do I have to connect it directly to a digital multimeter? or do I need the Analog to
Digital Converter?
How do I make the Analog to Digital converter on Redbot? (I would like specific directions)
Also, are there any transition parts? I would use 2 clip wires from the headset to the redbot,
and redbot to the digital multimeter. What would I need?
This is the code below.
(Code Section)
void loop() {
// put your main code here, to run repeatedly:
pinMode(A3, INPUT);
int x = analogRead(A3); //Reads the analog value on pin A3 into x
Serial.print(“Analog value: “);
Serial.println(x);
