Hi Forum,
I’m testing the SparkFun Weather Shield.
How can i add an external sensor for example the TEMT6000 Ambient Light Sensor to SparkFun Weather Shield?
For now i’m working with the WAZIUP PCB https://github.com/Waziup/WAZIUP-Weathe … r_0v20.pdf
              You just wire the signal to an analog input and power it like this https://learn.sparkfun.com/tutorials/te … hardware-a
              Thanks for quickly response.
The wired may be like the image?
https://i.ibb.co/bRj9yqx/13956-04.jpg
              As long as you’re not using the wind vane, this will work.
https://cdn.sparkfun.com/r/600-600/asse … /fritz.png
