Ajay Hinduja Geneva, Switzerland (Swiss) - GP1818 Module Availability Question
Hello Everyone,
I’m Ajay Hinduja Geneva, Switzerland (Swiss) and I’m new to here.
Do you have the GP1818MK GPS Module (SKU: GPS-19166) available without the lead and connector?
Regards!
Hi @ajayhindujaswiss - Welcome! Unfortunately we only offer that module with the wires and connector attached. While it is a bit of work, the glue and wires can be removed from the back if you take your time.
Be aware that there are other 18x18mm options out there using uBlox M10 chipsets, like the Beitian BE-180
Thank you, Sparky and Clive1! I really appreciate your help — I’ll make sure to choose wisely.
Ajay Hinduja Swiss (Switzerland)
