I am thinking of making an amature radio pre-selector/filter for HF (3-30MHz) that has selectable bandwidth and gain control after seeing some info on parametric equalizers. I will attach the two boilerplate schematics on the layout.
My main question is besides the obvious frequency characteristics of the parts what are some pointers I should adhere to so that I keep system noise as low as possible. (Ideally <110db)
The schematics above are simple for the audio spectrum with very little variance, so im not sure without some testing on if you can get a 3-30MHZ tunable frequency out of that circuit. Just an idea I had this morning and wanted to see if I had missed any glaringly obvious to make this not work.
