Hi all.
I want to use the jtagkey-tiny from amontec together with the sam7-ex256 development board from olimex. For some reason I don’t manage to get it work:
Info: openocd.c:92 main(): Open On-Chip Debugger (2007-07-31 19:00 CEST)
Error: jtag.c:1346 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x3f
Error: jtag.c:1442 jtag_init(): Could not validate JTAG chain, exit
I am a bit at a loss. The configuration file looks like this:
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc "Amontec JTAGkey"
ft2232_layout "jtagkey"
ft2232_vid_pid 0x0403 0xcff8
jtag_speed 0
jtag_nsrst_delay 200
jtag_ntrst_delay 200
#reset_config <signals> [combination] [trst_type] [srst_type]
reset_config srst_only
#jtag_device <IR length> <IR capture> <IR mask> <IDCODE instruction>
jtag_device 4 0x1 0xf 0xe
#daemon_startup <'attach'|'reset'>
daemon_startup reset
#target <type> <endianess> <reset_mode> <jtag#> [variant]
target arm7tdmi little reset_halt 0 arm7tdmi
#run_and_halt_time <target#> <time_in_ms>
run_and_halt_time 0 30
flash bank at91sam7 0 0 0 0 0
This is OpenOCD as in Debian Testing (r188?).
Any ideas what could be wrong?
Simon
