Hello SparkFun forums. I’m afraid I have to ask a simple question after exhausting online resources.
I have a sensor that, under normal conditions, sees a max voltage change of ~5mV. I’d like to amplify that by at least an order of magnitude if not more. I’ve looked into wheastone bridges, differential amplifiers, and common emitter amplifiers but I always hit the same problem: the amplification saturates at the supply voltage. A lot of the resources online show AC voltage, but my application is DC voltage.
Specifically, I’m trying to amplify voltage using the common-emitter amplifier circuit attached to this message. The transistor is the [BC337 from SparkFun.
“Rpot” is the resistance of a potentiometer. My goal is to change the voltage at the collector (Vc), by changing the resistance of the potentiometer. Problem is, no matter the voltage at the base (Vb), Vc is always the power supply’s voltage (9V in the picture attached).
I’m sure there is something fundamentally wrong with my understanding of voltage amplifiers and the solution is trivial, but I just can’t see it.
Op Amps were what I first tried and I could not get the circuit to respond to the sensor as i wanted. Specifically, I tried circuit outlined in Figure 1 on TI’s [Operational amplifier gain stability
