hi…
i am tring to transmit signal wirelessly with help of xbee…but i new to the xbee module…i dnt understand how i make connection for transmit signal wirelessly…i am trying to transmit transducer output which is analog signal to receiver side with help of xbee…if xbee covert analog signal, so for that which pin i have connect with xbee…or not then i use adc for converting analog to digital???
