Hello!
Does anybody know what type the ceramic antenna for the MiRF v2 - Module is?
http://www.sparkfun.com/commerce/produc … cts_id=691
I don’t need a socket, a ceramic antenna would be ok.
Where can I get such a ceramic antenna? (I’m from Switzerland)
Thanks a lot for any answers!!
Joni
http://www.sparkfun.com/commerce/produc … cts_id=144
Thank you very much!
Don’t put a ground track underneath it like SFE did!!!
Leon
Can you show or describe me, what SFE did? What’s this: SFE?
Just look at it, you’ll see what I mean. They use the same board for the ceramic antenna and an SMA connector. The pad is a ground connection for the SMA connector.
OK, thank you!
