Anyone building a wireless display out of your Microview?
I was thinking of making a wireless display using Xbee’s, but I hate reinventing the wheel, I was hoping to find an eagle file for the microview and design a small board that could be battery powered.
doobie:
I was hoping to find an eagle file for the microview […]
Eagle file for the MicroView is here:
https://github.com/geekammo/MicroView-PCB
That has the eagle file for the board, but what if I wanted to make a new board to connect to the microview, is there a library for that which has the pins sized/labeled? Sorry still new to eagle/doing my own PCBs.
I have a PCB that has connection to an Xbee, 5v to 3.3v regulator and lipo charger. Will be adding to the circuit a battery gauge, vibrator and one or two push buttons.
Hi doobie,
The USB programmer’s eagle file has a MicroView foot print and pins labeled. The github link is here
https://github.com/geekammo/MicroView-U … rammer-PCB
Cheers
JP
I’ve interfaced mine to an RN-XV, exactly the same pinout as an XBee but does Wifi instead. Pretty neat.
https://www.sparkfun.com/products/10822
Edit: If you end up making boards, I’d be interested in one or two!
