Arduino Mini Pro Pinout Diagram
Hi all,
a new pinout is out!
http://www.pighixxx.com/pgdev/Temp/ProMini.png
http://www.pighixxx.com/downloads/pro-mini/ to download HR version or PDF
The pins are backwards on the FTDI side. Also you’re missing A6 & A7. Note: A6 & A7 can only be used as analog in.
Also, A4 should be SDA instead of SCL.
Some Pro-Mini boards don’t have A6 &A7 (later? earlier?) - the Eagle files here don’t have them.
The other problems remain…
This series of pinout diagrams is brilliant, but only if they’re accurate!!!
I’m assuming the older versions don’t have A6 & A7 because the boards I’ve ordered over the last couple of months do have these pins.
duncan_a:
Just so other members are aware, these pinouts are accurate up to the latest releases. If you are getting the Eagle files from Sparkfun, you need to contact them and advise of the situation. Or you can try to get them from the source, http://arduino.cc/en/Main/ArduinoBoardProMini
