Hi all,
Thought id throw you an weird issue for my first post.
Ive the Arduino pro Mini 5v connected via the ftdi basic breakout board.
Up until several days ago it was reading the serial data correctly but now it almost seems to corrupt it on input.
e.g. im sending it an hex of #ffffff and it comes out as different ascii characters.
The strange part is that i can program it correctly as if i tell it in setup to turn some leds on then it does so, fine.
Any ideas whats causing it?
I’ve tried resinstalling the arduino software/drivers as well.
I have tested that my pc is sending the code correctly (via an serial port monitor)
