Arduino ProMicro - remove bootloader?
Yep. If you connect to the ISP pins with a programmer, the normal procedure will overwrite the bootloader.
In Arduino 1.0, the Shift-Upload button will “upload using programmer” (assuming you have one of the programmers that Arduino recognizes) instead of using the bootloader…
