Arduino Shield Question
hi how to use multiple shields in Arduino?
if i have two…
example, GSM and Ethernet can this work simultaneously in void setup?
void setup(){
Serial.begin(9600);
    if (gsm.begin(2400)){
        Serial.println("\nstatus=READY");
        started=true;
Ethernet.begin(mac, ip);
server.begin();
I think that all you need to worry about is using NewSoftserial for the second baud rate.
http://arduiniana.org/libraries/NewSoftSerial/
Also if you have hardware overlap, you can use the Go_Between shield to remap your pins
https://www.sparkfun.com/products/11002
