this is part of my arduino code. i want to read the serial on processing arduino. but i cannot input int val[8]; in processing. how can i write it ?
int checkCol(){
int val[8];
for(int i=0; i<num; i++){
digitalWrite(cols*,LOW); //anodes o/p and low*
pinMode(cols,OUTPUT);
digitalWrite(rows,LOW); //cathodes o/p and low
pinMode(rows,OUTPUT);
delayMicroseconds(10);
for(int j=0; j<num; j++){
pinMode(cols[j],INPUT);
delayMicroseconds(200);
for ( int col=0; col<num; col++ ){ // read analog values at all anodes
val[col] = analogRead( col );
for(int col=0; col<num; col++){ // calculate difference between current values and thresholds
val[col] = val[col] - thresh[col];
int signal = 8;
if(val[col] > 25){
signal = col;
break;
for( int col=0; col<7; col ++ ){
Serial.print(val[col]);
Serial.print(“,”);
Serial.println(val[7]);
return (signal);
