If I’m trying to connect 3.3V TTL serial devices to a Sparkfun RedBoard using SoftwareSerial, do I need a level shifter to avoid damaging the devices (https://www.sparkfun.com/products/12009 … 1442710417)? I’m trying to connect the following items.
GPS Receiver: https://www.sparkfun.com/products/13740
RockBLOCK Iridium SatComm Module: https://www.sparkfun.com/products/13745
One thing to note, I had actually hooked up the GPS before thinking about this question and did not damage it. However it only transmits data…it doesn’t have a RX wire, only TX. I’m guessing it was only transmitting at 3.3V to the Arduino, so it wasn’t in danger of being damaged by 5V signals coming from the board.
Good thing I realized this before trying to hookup the RockBLOCK…it’s a bit expensive!
