Sorry, I ask this on another group, but find it was not a good fit.
I’m getting my son involved in an Arduino project.
I have an electronics background, but no processor/programming background
My son will actually do better in the programming area.
We are building a Mung beans sprouter for my wife (more to learn, but we also grow sprouts)
The will include a temp sensor and heater-- Adjustable
An LCD Display to see and set the temperature and set schedule and on time.
And a timer to drive a pump to water the sprouts.
If possible I would like to be able to set the watering schedule and the amount of on time.
Can an Arduino UNO do all three processes?
Is there enough inputs to adjust the temp and also to adjust schedule and on time?
I have 12V heat pads, LM35 temp sensor, Relays, Suspect I can come up with a 12V supply with enough capacity to
run the heater, and pump.
I have a pump, but may or may not use the one I have.
Need Arduino or would it be better to have a Redboard, cheaper is better, but not necessary.
Also, need a display, maybe Jumpers? A case and what else?
Also, I didn’t find a UNO specific Forum. Is there one?
Thanks all, Mavam
