ARM and MIP count
I can’t find the MIP count of the Philips ARM used in Sparkfun kits. Does anybody know the numbers or can direct me to them?
Thanks in advance.
Getting on for 60 MIPS with the correct clock settings, FWIW.
Leon
Thanks a lot for the info!
ARM7 have 0.9MIPS per Mhz so correct answer is 54 MIPS when LPC runs on 60 Mhz
Best regards
Tsvetan
Thanks for the correction. 54 MIPs should be enough for the kind of things I want to do.
