ARM: UART in LPC 2378
Dear all,
here I did UART implementation in LPC 2378.
but whever I transmitting data on serial and observed at Hyperterminal.I am not getting data in hex format.I am getting in ascci format.
suppose I am sending hex 0x15,on hyperterminal then I am getting charactor having ASSCI having 0x15.
how cam get data in HEX format on hyperterminal.
waitting for ur reply…
thanks.
“I am sending hex 0x15,on hyperterminal then I am getting charactor having ASSCI having 0x15.”
Of course you do: that is exactly what hyperterminal - or any other text-based application - is expected to do!
Do you mean, instead of the byte value 0x15, you want to transmit the two characters ‘1’ and ‘5’ ?
ie, you want to transmit two bytes containing the values 0x31 and 0x35 - being the ASCII codes for ‘1’ and ‘5’ … ?
Is that what you mean?
