ARM-USB-OCD issues straight out of box for STM32 and win7-64
I just bought an Olimex ARM-USB-OCD and used the supplied CD to install eclipse, openOCD, codesourcery, etc, and it doesn’t seem to be allowing me to debug my STM32F103RET6 on my custom board.
I know I don’t have any problems with my target board or the ARM-USB-OCD itself, because the eval version of Crossworks can connect to the target fine.
I follow the instructions in the HOW_TO_INSTALL.txt on the CD,
  1. launch eclipse
  2. open the given stm32f103-stk project
  3. Build the project
  4. Run → External Tools → OpenOCD for STM32
and I get the following in Console tab:
Open On-Chip Debugger 1.0 (2008-10-15-13:12) svn:exported
$URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/src/openocd.c $
Info:    options.c:50 configuration_output_handler(): jtag_speed: 10, 10
Info:    options.c:50 configuration_output_handler(): Open On-Chip Debugger 1.0 (2008-10-15-13:12) svn:exported
Info:    jtag.c:1369 jtag_examine_chain(): JTAG device found: 0x3ba00477 (Manufacturer: 0x23b, Part: 0xba00, Version: 0x3)
Info:    jtag.c:1369 jtag_examine_chain(): JTAG device found: 0x06414041 (Manufacturer: 0x020, Part: 0x6414, Version: 0x0)
Error:   jtag.c:927 jtag_add_reset(): BUG: transition of req_tlr_or_trst and req_srst in the same jtag_add_reset() call is undefined
I realised this error isn’t necessarily fatal, so I then continue on with:
  1. Run → Debug Configurations → Zylin Embedded debug (Cygwin) → stm32f103-stk → Debug
and a error box pops up which says “Execution is suspended because of error”, with details “cont, The program is not being run”. In the console appears:
Warning: /cygdrive/C/gccfd/projects/stm32f103-stk: No such file or directory.
No source file named main.out.
No registers.
target remote localhost:3333
Remote connection closed
monitor soft_reset_halt
"monitor" command not supported by this target.
monitor flash erase_sector 0 0 3
monitor flash write_image main.bin 0x0
break main
1breakpointkeepy   0x00000014in main at main.c:43
Breakpoint 1 at 0x14: file main.c, line 43.
cont
The program is not being run.
