Hi All,
i downloaded the demo code from Olimex site and tried to open the project (by clicking SAM7_EX256.eww ) in IAR workbench (Embedded Workbench 4.0 Kickstart) . But every time i get the this warning :
IAR Embedded Workbench IDE
Broken options were detected in the project file.
A backup copy will be made.
(See log window for details)
OK
The log shows :
LOAD: Configuration ‘Debug’ in the project ‘SAM7_EX256’ contains broken options for tool ‘General’:
The format of this file is not supported by this version of the workbench. It appears to have been written by a newer version of the workbench.
Diagnostics: ‘Unsupported version 5 of list option descriptor ‘Variant’’.
Options for ‘General’ will be set to default.
Creating backup of original project file.
LOAD: Configuration ‘Debug’ in the project ‘SAM7_EX256’ contains broken options for tool ‘AARM’:
Diagnostics: ‘Settings ‘AARM’: unsupported version - 7’.
Options for ‘AARM’ will be set to default.
LOAD: Configuration ‘Debug’ in the project ‘SAM7_EX256’ contains broken options for tool ‘XLINK’:
Diagnostics: ‘Settings ‘XLINK’: unsupported version - 18’.
Options for ‘XLINK’ will be set to default.
LOAD: Configuration ‘Release’ in the project ‘SAM7_EX256’ contains broken options for tool ‘General’:
LOAD: Configuration ‘Release’ in the project ‘SAM7_EX256’ contains broken options for tool ‘AARM’:
LOAD: Configuration ‘Release’ in the project ‘SAM7_EX256’ contains broken options for tool ‘XLINK’:
LOAD: Configuration ‘BIN’ in the project ‘SAM7_EX256’ contains broken options for tool ‘General’:
LOAD: Configuration ‘BIN’ in the project ‘SAM7_EX256’ contains broken options for tool ‘AARM’:
LOAD: Configuration ‘BIN’ in the project ‘SAM7_EX256’ contains broken options for tool ‘XLINK’:
Then when i try to make the project i get around 200 errors :
Building configuration: SAM7_EX256 - BIN
Updating build tree…
main_all.c
Error[Pe040]: expected an identifier L:\SAM7_EX256\ioat91sam7x256.h 2749
Error[Pe018]: expected a “)” L:\SAM7_EX256\ioat91sam7x256.h 2749
Error[Pe065]: expected a “;” L:\SAM7_EX256\ioat91sam7x256.h 2749
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2749
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2750
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2751
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2752
Warning[Pe012]: parsing restarts here after previous syntax error L:\SAM7_EX256\ioat91sam7x256.h 2759
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2759
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2760
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2761
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2762
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2763
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2764
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2765
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2767
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2768
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2769
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2770
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2771
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2772
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2773
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2774
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2775
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2776
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2777
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2778
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2780
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2781
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2782
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2783
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2784
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2785
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2786
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2787
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2788
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2789
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2790
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2791
Warning[Pe012]: parsing restarts here after previous syntax error L:\SAM7_EX256\ioat91sam7x256.h 2796
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2796
Warning[Pe012]: parsing restarts here after previous syntax error L:\SAM7_EX256\ioat91sam7x256.h 2806
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2806
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2807
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2808
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2810
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2811
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2813
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2814
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2815
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2816
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2817
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2818
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2819
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2820
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2821
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2822
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2823
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2824
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2825
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2826
Warning[Pe012]: parsing restarts here after previous syntax error L:\SAM7_EX256\ioat91sam7x256.h 2832
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2832
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2833
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2834
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2835
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2836
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2837
Warning[Pe012]: parsing restarts here after previous syntax error L:\SAM7_EX256\ioat91sam7x256.h 2844
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2844
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2845
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2846
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2847
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2848
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2849
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2850
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2851
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2852
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2853
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2854
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2855
Warning[Pe012]: parsing restarts here after previous syntax error L:\SAM7_EX256\ioat91sam7x256.h 2858
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2858
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2859
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2860
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2861
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2862
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2863
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2864
Warning[Pe012]: parsing restarts here after previous syntax error L:\SAM7_EX256\ioat91sam7x256.h 2873
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2873
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2874
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2875
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2876
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2878
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2879
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2880
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2881
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2882
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2883
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2884
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2885
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2886
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2887
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2888
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2890
Error[Pe169]: expected a declaration L:\SAM7_EX256\ioat91sam7x256.h 2891
test.c
Total number of errors: 200
Total number of warnings: 14
is there any setting that i am missing !!
help please … all help will be highly valued …
regards,
som
