We are using the AT91SAM9G20 for a school project. We bumped into a problem as we need to support hardware floating point, and the AT91SAM9G20 does not.
However, we know that the processor in the microcontroller (ARM926EJ-S) does support a floating point co-processor.
Also, in the AT91SG20 datasheet it says that it supports SPI co-processor. Has anyone here used this chip or done something similar? Would it be safe for us to order the uM-FPU v3.1 here at Sparkfun and assume that it will work?
Thanks for any answers ![]()
datasheet for AT91SG20: http://www.keil.com/dd/docs/datashts/at … g20_ds.pdf
Floating Point Co-Processor http://www.sparkfun.com/commerce/produc … ts_id=8129
Edit: Sorry. I guess i should have moved this to the ARM section, as this atmel chip is not AVR but uses the ARM9 processor. I will repost it there ![]()
