Hi!
I am using an Atmega644p. I am using Port A as an output but then setting all pins to low. But pins 6 and 7 seem to sit at 3 and 4 volts respectively. I cannot seem to make them go low.
My circuit is quite simple: Vcc - 5v, Gnd - 0v, AVcc - 5v, AGnd - 0v, reset - (ISP) - 4k7 - 5v, Mosi - ISP, Miso - ISP, SCK - ISP.
I am measuring voltages with a multimeter. The chip is running at 20Mhz.
Code goes:
DDRA 0b11111111;
PORTA = 0b00000000;
while(1==1)
I hope someone can point out what I am doing wrong!
Thanks! ![]()
