Atmega32u4 Breakout, IDE & Atmel Flip?
Hi Everyone,
I’ve done a bunch of searching online trying to figure this out but I haven’t been successful. Does anyone know if there’s a full-fledged graphical IDE out there which will work with this board? Also, does anyone know if this board can be programmed using the Atmel flip utility? I installed the INF driver for this board, it enumerates as a com port for me (COM5), but Flip doesn’t seem to recognize any RS-232 communication, or really provide a way for me to connect to the board.
I found a tutorial online about setting up eclipse with the AVRdude/winAVR plugin. I followed that and it seems to be mostly set up correctly, but I don’t know which programmer to select within the options to program over USB/the enumerated COM port. Any help would be greatly appreciated, I’d like to avoid command line tools if at all possible.
Thanks.
  • Chris
I’ve just received my SparkFun ATmega32u4 the other day and have been dealing with exactly the same issue. Flip doesn’t see it over USB and I don’t have a programmer to write to flash. I understand Flip requires that you install their drivers for the chip but Windows always rejects it, will only accept the SparkFun drivers that Flip can’t understand.
My issue was with 64bit Windows 7, I managed to program it with AVR109 in AVRdude inside of a Windows XP virtual machine (VMWare player)
WayfaringNinja:
I never had any problems programming with AVR109 and AVRdude, that always worked for me (I use Win7 x64). I was simply looking for a simpler alternative to program the controller (e.g. FLIP) and could never get FLIP to work.
