Hi all,
I’m using the ATSAMD21G18AU board whose details are here : https://www.sparkfun.com/products/13664
I have successfully flashed the Circuit python based bootloaders from :
https://github.com/adafruit/uf2-samdx1/releases
But when i try to use this board with MPLAB harmony X IDE tool v5.45, the project is not recognizing any hardware tool
Hence, i flashed bootloader suggested here : https://www.instructables.com/ATSAMD21g … -Debugger/
Still I cant used this board, kindly suggest the bootloader to flash and obtain USB port registered for this board.
Inturn, which would help in MPLAB X IDE tool based driver read/write.
