What is the voltage to GPIO4, in the attached picture? Or what range is acceptable?
Was this diagram from one of our tutorials? Also, you can measure that voltage with a multimeter. The accepted logic levels should be maximum of 3.3V. So, depending on your resistor values, it should be less than 3.3V.
