AVR Newbie Needs Help Urgent plzzzzzzzzzzz
hello
i have gone through the tutorials and i got all the necessary components
The programmer i used was from robokit
http://www.robokits.org/products/?p=pro … ompatible)
I have connected everthing as given in the tutorial
The power LED on the programmer is glowing dim wen i connected it to the parallel port
Wen i connected it to the AVR chip it is glowing brightly
But wen i click on AVR program
It is showing AVR device cannot be acessed
doubloe chek the connections it is showing
I checked all the connections using a multimeter
but can’t find what is wrong
The buffer chip on the programmer is 74HC541N
Where i am going wrong ?
Am i using a wrong software r wat
plz kindly help me
Vendor claims it’s STK200 compatible. So if you use Atmel’s AVR Studio it’s supposed to work. Studio has a built-in programmer.
Parallel port access, as you know, is prohibited in Windows XP. The work-round is a special OS driver.
Much better to use a serial or USB port programmer.
Then plz kindly let me know
how to gain parallel port access in windows XP
if there is any software etc…
plz kindly help me
giveio.sys is often used with gcc applications.
Leon
