Has anyone used this USB AVR programmer, or have a recommendation for another one. I need a USB programmer, as I don’t have a standard parallel or serial port.
http://www.mikroe.com/en/tools/avrprog2/
Thanks, for any help.
SMBogan
SMBogan
I use Atmel’s AVRISP MK2; you can get them from DigiKey for $36.
http://www.digikey.com/scripts/DkSearch … AVRISP2-ND
/mike
thanks, I’ll give that one a try.
The Atmel Dragon is a USB debugger/programmer for the AVR. It costs more than the AVRISP but is a lot more useful.
Leon
I use BSD AVRDUDE programmer. It is the cheapest one available, See the programmer
http://avrmicrocontroller.googlepages.c … ammer.html
Bibin John
I have started to carry a new, low-cost, AVR programmer by a company named Small RF Budget. The programmer was designed by two German engineers that are pretty fanatical about quality.
I have the programmer listed here, along with target cables:
I have some info on programmers here:
http://www.EricEngler.com/downloads/AVR … ammers.txt
I’m a fan of the dragon because it can support in-circuit debugging as well as ISP programming. But it doesn’t come with headers so you have to do some soldering.
The ISP devices that come pre-wired are easier for newbies. I prefer the USB devices unless your budget is real small. Many computers don’t have serial and parallel ports now.
Eric
http://ladyada.net/make/usbtinyisp/ (click “Buy Kit” on the left)
many options available: kit, just the board, just the chip, etc.
i ordered one, built it in an hour or so, and it works great with avrdude (i’m on debian linux, but it should work under win/mac too)
