Hi everybody !
I have done some Xcode templates for AVR users on Mac OS X. It’s very usefull to create AVR projects.
http://www.tech-hob.fr/AVRXcodeTemplates.zip
See you,
Vincent
Hi everybody !
See you,
Vincent
Those are great! It won’t compile for me, though. I am using CrossPack-AVR as my toolchain. I imagine the path for avr-gcc is not correct for that toolchain. Any ideas on how to correct this?
Thank you ![]()
I think you’re right, in your project, open the Target menu, then open the corresponding device submenu and read the information of the Run Script. If you use CrossPack-AVR, you must change the export path to :
PATH=/usr/local/CrossPack-AVR/bin:$PATH
That did the trick, thanks!
Does anyone have these templates online, or an updated link?
I would like to post them on osx-avr.org so that they will stay on the net.
Yes, I forgotten that I had put it on my website. I can send you the folder by email if you want, it’s not a problem.
See you !
the link is not available anymore… can anybody post it?
The zip file is too big I can’t put it on the forum. If you want I can send it you by email ?
