- How do you add the library to the arduino programmer to control these?
2.how do you set the servo ids to control them?
- Will you give me a sample of code to move the third servo in a connection of 3 to 90 degrees and then to 120 degrees?
I have been trying to follow this link to install the libraries but it isnt working. I copied the files to the libraries file and made sure the names were the same. When i open arduino programming and import the library, it brings up two lines```
#include <Ax12.h> #include <BioloidController.h>
[http://www.projectsofdan.com/?p=45](http://www.projectsofdan.com/?p=45)
Thanks For the help. I'm completely lost
