Hi
I have a problem with the current sensor Low Current Sensor ACS723
My code written in arduino ide environment:
const int analogInPin = 14;
const int infoPin = 27;
// Number of samples to average the reading over
// Change this to make the reading smoother… but beware of buffer overflows!
const int avgSamples = 10;
int sensorValue = 0;
float sensitivity = 100.0 / 500.0; //100mA per 500mV = 0.2
float Vref = 2500; // Output voltage with no current: ~ 2500mV or 2.5V
float calculatecurrent;
void setup() {
// initialize serial communications at 9600 bps:
Serial.begin(115200);//, SERIAL_8N1, RX, TX);
pinMode(infoPin, OUTPUT);
void loop() {
// read the analog in value:
for (int i = 0; i < avgSamples; i++)
sensorValue += analogRead(analogInPin);
// wait 2 milliseconds before the next loop
// for the analog-to-digital converter to settle
// after the last reading:
delay(2);
sensorValue = sensorValue / avgSamples;
// The on-board ADC is 10-bits → 2^10 = 1024 → 5V / 1024 ~= 4.88mV
// The voltage is in millivolts
float voltage = 1.22 * sensorValue; //4.88 * sensorValue;
// This will calculate the actual current (in mA)
// Using the Vref and sensitivity settings you configure
float current = (voltage - Vref) * sensitivity;
// This is the raw sensor value, not very useful without some calculations
//Serial.print(sensorValue);
Step 1.)
Uncomment and run the following code to set up the baseline voltage
(the voltage with 0 current flowing through the device).
Make sure no current is flowing through the IP+ and IP- terminals during this part!
The output units are in millivolts. Use the Arduino IDE’s Tools->Serial Plotter
To see a plot of the output. Adjust the Vref potentiometer to set the reference
voltage. This allows the sensor to output positive and negative currents!
//Serial.println(voltage);
//Serial.print(“mV”);
Step 2.)
Keep running the same code as above to set up the sensitivity
(how many millivolts are output per Amp of current.
This time, use a known load current (measure this with a multimeter)
to give a constant output voltage. Adjust the sensitivity by turning the
gain potentiometer.
The sensitivity will be (known current)/(Vreading - Vref).
Step 3.)
Comment out the code used for the last two parts and uncomment the following code.
When you have performed the calibration steps above, make sure to change the
global variables “sensitivity” and “Vref” to what you have set up.
This next line of code will print out the calculated current from these parameters.
The output is in mA
//Serial.print(" current mA");
calculatecurrent = abs(current);
Serial.println(calculatecurrent);
//Serial.write(10);
if ((calculatecurrent < 40) || (calculatecurrent > 85)){
digitalWrite(infoPin, HIGH);
//Serial.write(10);
else{
digitalWrite(infoPin, LOW);
//Serial.write(0);
// – DO NOT UNCOMMENT BELOW THIS LINE –
Serial.print(“\n”);
// Reset the sensor value for the next reading
sensorValue = 0;
I use ESP32 v4 microcontroller to control a linear motor. Without load it has about 20 mA under load it increases to even approx. 100 mA.
The sensor shows a value of about 70 (not including noise). Under load the value changes but it is not the correct value how can I fix it?
