I would like to thank everyone that has helped so far. I’ve made good progress and I’m on the final approach.
I have a good portion of my bee hive monitoring project completed. I have a[ redboard, [qwiic scale, [Zio qwiic loudness sensor and the [environmental combo breakout. I have the sketch (beehive_master) running and it is pulling data every 15 minutes to my Raspberry Pi which then updates MySQL.
I have two Differential I2C breakouts that I thought were bad because every time I plugged everything in the sketch would fail on the Redboard. I decided to play around with them and hooked up an Artemis, the differential breakout and an environmental combo breakout. Loaded the sample code and voila, data. I then added the scale, rewrite code and everything works. I then hooked up the loudness card and uploaded the beehive_master sketch and BAM! Cannot find the scale. Disconnect the loudness breakout and the scale is found. I tried removing the environmental breakout and it still failed. If I move the loudness breakout to the front differential breakout – coming from the redboard – everything works. From the documents it seems as though the scale and loudness breakouts have different addresses.
Any ideas?](https://www.sparkfun.com/products/14348)](https://www.sparkfun.com/products/15892)](https://www.sparkfun.com/products/15242)](SparkFun RedBoard Qwiic - DEV-15123 - SparkFun Electronics)
