Hi, hoping to get some help on this. I followed the tutorial but no luck.
------- PART 1 ---- SOLVED
I just bought the Bluetooth Modem - BlueDongle RS232. I did not have a RS232 port so bought a USB to RS232 cable. I connected it to the computer, connected the miniB usb cable for power, and then it appeared in my device manager as ‘Serial on USB (COM51)’
I then opened hyperterminal, created a new connection to COM51 with 9600, 8 data bits, no parity, 1 stop bit and hardware flow control, then clicked ok.
I then tried to type AT into the terimal window, but for some reason i could not type anything. nothing i typed on the keyboard appeared in the window. i then did some searching and found out i had to go to properties, settings, ascii setup, and check next to ‘echo typed characters locally’.
once i did this i could type in the terminal window. so i typed AT but nothing happened. i tried again and still nothing…
i know the BlueDongle is supposed to be easy to use but as you can tell i cannot get it working.
So i am calling out for anyone to help me. im using windows XP, can anyone provide me with a simple set of instructions which they used to set up the bluedongle
------- PART 2 -----
i have a [BlueSmirf modem connected to an Arduino microcontroller that would like to send data to from my computer. previously i used a standard [bluetooth USB module which worked fine, but now im trying to use the [BlueDongle.
Has anyone done anything similar? or can anyone tell me how to detect/connect and create a COM port for my bluesmirf modem using the BlueDongle?
any help will be much appreciated… Thanks guys](http://www.sparkfun.com/commerce/product_info.php?products_id=642)](http://www.sparkfun.com/commerce/product_info.php?products_id=150)](Bluetooth Modem - BlueSMiRF Gold (Old-School) - WRL-00582 - SparkFun Electronics)
