I’ve been trying to get my new cell (Sony Ericsson w810i Cingular Provider) to talk to hyperterminal for about a week now.
First, I went to the phone manufacturer’s website and got a software dev kit. They will probably have one based on the Java Wireless Toolkit if your phone can run Java games. Using this toolkit you will be able to create midlets (phone java apps).
If you’re phone supports the Bluetooth API (JSR 82) then you will be able to create midlets that can perform bluetooth device discovery, connect, and send data to other bluetooth devices. You’d probably use the serial port profile of the BlueRadio stack to do the talkin.
I found a good website that explains all that pretty well.
The problem I’m having is that Cingular doesn’t allow access to the bluetooth port on my phone through unsigned midlets, and getting a certificate to sign my midlet from Verisign or Thawte would cost +$500. I looked into putting a fake root certificate using OpenSSL on my phone and signing my midlet with it, but the phone won’t take it. (If anybody knows how to get around this PLEASE LET ME KNOW!!!.. :oops: I wonder if debranding/unlocking the phone would get rid of these restrictions… )
So I guess the short answer is that it depends on your phone haha.
After some messing around I finally got midlets working on my phone (a Motorola Razr V3i), and I can talk to the bluesmirf from it. The device and service discovery are a pain but once that’s done you can connect using the GCF connection object with the btspp: (bluetooth serial port profile) protocol scheme from my custom java applet.
