Removing the 8MHz crystal and patching in a 16MHz clock did the trick, at least to begin with.
It is now recognized as a serial port device (USB descriptor below).
However, I’d still like to get it back to stock functionality on its 8MHz crystal. This is important since the end application is fixed at 3.3V.
The GUI seems able to program it as a 16MHz device. It even enumerates in Windows as a COM device after that. But it does not come back when I change it to 8MHz and power cycle it.
Thanks for any advice!
Børge
Information for device Arduino Micro (VID=0x2341 PID=0x8037):
Connection Information:
Device current bus speed: FullSpeed
Device supports USB 1.1 specification
Device supports USB 2.0 specification
Device address: 0x0013
Current configuration value: 0x01
Number of open pipes: 3
Device Descriptor:
0x12 bLength
0x01 bDescriptorType
0x0200 bcdUSB
0xEF bDeviceClass (Miscellaneous device)
0x02 bDeviceSubClass
0x01 bDeviceProtocol
0x40 bMaxPacketSize0 (64 bytes)
0x2341 idVendor
0x8037 idProduct
0x0100 bcdDevice
0x01 iManufacturer “Arduino LLC”
0x02 iProduct “Arduino Micro”
0x03 iSerialNumber
0x01 bNumConfigurations
Configuration Descriptor:
0x09 bLength
0x02 bDescriptorType
0x004B wTotalLength (75 bytes)
0x02 bNumInterfaces
0x01 bConfigurationValue
0x00 iConfiguration
0xA0 bmAttributes (Bus-powered Device, Remote-Wakeup)
0xFA bMaxPower (500 mA)
Interface Association Descriptor:
0x08 bLength
0x0B bDescriptorType
0x00 bFirstInterface
0x02 bInterfaceCount
0x02 bFunctionClass (Communication Device Class)
0x02 bFunctionSubClass (Abstract Control Model - ACM)
0x00 bFunctionProtocol
0x00 iFunction
Interface Descriptor:
0x09 bLength
0x04 bDescriptorType
0x00 bInterfaceNumber
0x00 bAlternateSetting
0x01 bNumEndPoints
0x02 bInterfaceClass (Communication Device Class)
0x02 bInterfaceSubClass (Abstract Control Model - ACM)
0x00 bInterfaceProtocol
0x00 iInterface
CDC Header Functional Descriptor:
0x05 bFunctionalLength
0x24 bDescriptorType
0x00 bDescriptorSubtype
0x0110 bcdCDC
CDC Call Management Functional Descriptor:
0x01 bDescriptorSubtype
0x01 bmCapabilities
0x01 bDataInterface
CDC Abstract Control Management Functional Descriptor:
0x04 bFunctionalLength
0x02 bDescriptorSubtype
0x06 bmCapabilities
CDC Union Functional Descriptor:
0x06 bDescriptorSubtype
0x00 bControlInterface
0x01 bSubordinateInterface(0)
Endpoint Descriptor:
0x07 bLength
0x05 bDescriptorType
0x81 bEndpointAddress (IN endpoint 1)
0x03 bmAttributes (Transfer: Interrupt / Synch: None / Usage: Data)
0x0010 wMaxPacketSize (1 x 16 bytes)
0x40 bInterval (64 frames)
0x09 bLength
0x01 bInterfaceNumber
0x02 bNumEndPoints
0x0A bInterfaceClass (CDC Data)
0x00 bInterfaceSubClass
0x00 iInterface
0x07 bLength
0x02 bEndpointAddress (OUT endpoint 2)
0x02 bmAttributes (Transfer: Bulk / Synch: None / Usage: Data)
0x0040 wMaxPacketSize (64 bytes)
0x00 bInterval
0x07 bLength
0x83 bEndpointAddress (IN endpoint 3)
0x00 bInterval
Microsoft OS Descriptor is not available. Error code: 0x0000001F
String Descriptor Table
Index LANGID String
0x00 0x0000 0x0409
0x01 0x0409 “Arduino LLC”
0x02 0x0409 “Arduino Micro”
0x03 0x0409 Request failed with 0x0000001F
Connection path for device:
USB xHCI Compliant Host Controller
Root Hub
Generic USB Hub
Generic USB Hub
Arduino Micro (VID=0x2341 PID=0x8037) Port: 1
Running on: Windows 10 or greater (Build Version 22631)
Brought to you by TDD v2.17.0, Feb 23 2021, 14:04:02
Device Descriptor:
0x12 bLength
0x0200 bcdUSB
0x2341 idVendor
0x8037 idProduct
0x0100 bcdDevice
0x03 iSerialNumber
0x09 bLength
0x02 bNumInterfaces
0x00 iConfiguration
0x08 bLength
0x00 iFunction
0x09 bLength
0x01 bNumEndPoints
0x00 iInterface
0x0110 bcdCDC
0x01 bmCapabilities
0x01 bDataInterface
0x06 bmCapabilities
0x07 bLength
0x09 bLength
0x02 bNumEndPoints
0x00 iInterface
0x07 bLength
0x00 bInterval
0x07 bLength
0x00 bInterval
Index LANGID String
0x00 0x0000 0x0409
Root Hub
Generic USB Hub
Generic USB Hub
