Building a range finder that needs analog output
What equipment / parts would I need to build a range finder:
I would like to use the Ultrasonic Distance Sensor - HC-SR04 but not sure what other modules I would need to make it analog output.
I’m trying to detect 0 to 15’ range needs to be analog output 0 to 10 volts.
Any help would be great
Any microprocessor would work, but you would need an external 0-10V DAC module to generate the analog output signal.
This DAC module has a boost converter on board, so that it can be powered by 5V and still generate 0-10V. https://store.ncd.io/product/1-channel- … -i%C2%B2c/
