Hi All,
Just couple of days ago, mistakenly I have inverted Ground and Power cables and connected my Locosys LS20031 gps.
In result something burned. It doesn’t power up anymore.
Does anyone know if this can be fixed?
Is there any resistor that i can exchange and bring my GPS back to life?
I would be thankful for any help.
Reversing the supply like that usually damages lots of things, you probably need to get a new one.
yep, this is what i thought so
I just had a hope that someone had done the same and found a solution that one or two parts can be changed and this would bring the module back to life.
I guess I will need to search for a new gps module.
