We are using WRL-18569 (RP-SMA to U.FL cable 150mm) for our products and I need the cable loss value of this cable.
Could you kindly provide me with this value ?
Best Regards,
Best Regards,
That one doesn’t have a datasheet associated, but I found several comparable ones that list 50 ohms…probably best to determine with a multimeter
Unfortunately, neither cable loss nor impedance can be measured with a multimeter. I agree that it is a 50 ohm cable. https://www.sparkfun.com/products/18154 (a 100mm similar cable) lists -2dB of loss. Assuming of course that the cable doesn’t have gain, it really has 2dB of loss, so the 150mm would likely have 1.5 times the loss
/mike
Thank you very much for your replies.
I will take 3dB.
Best Regards,
