If anyone could please help to shed some light on this issue I am starting to explore. Are there links? Resources? Is it possible? Should I get the SparkFun ESP32 Thing? Ultimately I want to have the ESP32 on some wearable item and remotely control my DAW (Ableton) … Is that possible using Ableton link? If so how? Or are there other ways to work around? Other suggestions? I hope to hear!
I do not know for sure but there is an Arduino library for Apple/RTP MIDI (MIDI over WiFi).
Hi, this Arduino library URL you gave me is for Arduino… Are you saying it works with the ESP32 as well? Ableton already links directly with Arduino using the Connect Max 4 Live device, although not wirelessly I believe. I am asking about using your product, the ESP32. So you are saying there are no options with your products? You are not sure?.. Can you please explain?..
