Hi everyone,
I have designed a simple regulated power supply board for my quad’s electronics (camera, gimbals, etc). I would love to have expert’s opinion and correction to the design (actually it is my first time doing it).
Secondly, does SparkFun provide PCB printing service if I send the Eagle file? Can anyone recommend a shop or way to have it printed?
Thanks a lot for your help!
Sincerely,
Patrick Shim
Well, we would need to see your board to give any feedback… I use [OSHPark for my boards.](https://oshpark.com/)
If you want to design a PCB circuit of Specific electronics circuit, here is a step by step tutorial to design a simple PCB circuit.
In the example, they have used an LED flasher circuit, if you follow the tutorial, then you may create and design your own PCB Circuit design
[How To Design a PCB - Step by Step & images view of LED Flasher Circuit PCB Design)
I hope you will learn something new from the above basic pcb design tutorial. Thanks 8)](PCB Designing: How To Design a PCB - Step by Step Guide)
