I’m not sure if I’m dealing with defective product, or I’m doing something wildly wrong. Would I need to configure anything differently for the TNC antenna?
I’ve used this 10m cable https://www.sparkfun.com/products/21740 - using such a long cable would I need to inject power additionally? If so, how do I do that?
I’ve checked voltage at the end of the TNC and it’s within the 3 - 3.3 range, and this should work with this antenna. It was also featured in one of the tutorials.
If you’re measuring ~3.3V at the end of your SMA+TNC cable I suspect it’s a faulty antenna. The TOP106 antennas are good but not without its failures. I recommend starting a issue with Tech Support for a replacement: https://www.sparkfun.com/returns
