I’m attempting to read the CAN ID from a device that uses the CAN 29-bit extended frame format. The device manufacturer’s CAN utility (using SYS TEC CAN-to-USB dongle) returns an extended ID = 0780203C, and that matches the expected value from the documentation I have. However, using the ASTCanLib with the AST-CAN485 board, msg->id.ext and msg->id.std return the same value = 203C.
Without the entire ID I cannot distinguish between the two packet types (ID 0780203C and ID 0781203C) I need to read and parse.
Any help is much appreciated.
Code follows (simply-modified example from library):
* CAN port receiver example
* Receives data on the CAN bus and prints to the serial port
#include <ASTCanLib.h>
#define MESSAGE_ID 0 // Message ID
#define MESSAGE_PROTOCOL 1 // CAN protocol (0: CAN 2.0A, 1: CAN 2.0B)
#define MESSAGE_LENGTH 8 // Data length: 8 bytes
#define MESSAGE_RTR 0 // rtr bit
// Function prototypes
void serialPrintData(st_cmd_t *msg);
// CAN message object
st_cmd_t Msg;
// Buffer for CAN data
uint8_t Buffer[8] = {};
void setup() {
canInit(1000000); // Initialise CAN port. Must be before Serial.begin
Serial.begin(9600); // start serial port
Msg.pt_data = &Buffer[0]; // reference message data to buffer
// Initialise CAN packet.
// All of these will be overwritten by a received packet
Msg.ctrl.ide = MESSAGE_PROTOCOL; // Set CAN protocol (0: CAN 2.0A, 1: CAN 2.0B)
Msg.id.ext = MESSAGE_ID; // Set message ID
Msg.dlc = MESSAGE_LENGTH; // Data length: 8 bytes
Msg.ctrl.rtr = MESSAGE_RTR; // Set rtr bit
void loop() {
// Clear the message buffer
clearBuffer(&Buffer[0]);
// Send command to the CAN port controller
Msg.cmd = CMD_RX_DATA;
// Wait for the command to be accepted by the controller
while(can_cmd(&Msg) != CAN_CMD_ACCEPTED);
// Wait for command to finish executing
while(can_get_status(&Msg) == CAN_STATUS_NOT_COMPLETED);
// Data is now available in the message object
// Print received data to the terminal
serialPrintData(&Msg);
void serialPrintData(st_cmd_t *msg){
char textBuffer[80] = {0};
sprintf(textBuffer,"id_ext %08X ",(msg->id.ext));
Serial.print(textBuffer);
// sprintf(textBuffer,"id_std %08X ",(msg->id.std));
// Serial.print(textBuffer);
// IDE
sprintf(textBuffer,"ide %d ",msg->ctrl.ide);
// RTR
sprintf(textBuffer,"rtr %d ",msg->ctrl.rtr);
// DLC
sprintf(textBuffer,"dlc %d ",msg->dlc);
// Data
sprintf(textBuffer,"data ");
// for (int i =0; i<msg->dlc; i++){
// sprintf(textBuffer,"%02X ",msg->pt_data[i]);
Serial.print("\r\n");
Some output:
id_ext 0000203C ide 1 rtr 0 dlc 8 data 01 28 00 00 00 00 19 32
id_ext 0000203C ide 1 rtr 0 dlc 8 data 00 C0 85 00 00 00 00 00
data 01 28 00 00 00 00 19 32 messages have an extended ID = 0781203C
data 00 C0 85 00 00 00 00 00 messages have an extended ID = 0780203C
