As per subject.
I can connect into a NAS server with running telnet in a Command prompt, so telnet can initiate a connection through the firewall.
I’m using OpenOCD 0.7.0 and the firewall is set for this program to accept incoming connections
I run a batch file containing OpenOCD and a couple of .fg files and I get the typical expected response.
After typing:
telnet localhost 4444
rather than getting an error I get a blank screen and then after a long while I get back the C: prompt.
Any ideas to what’s going on?
