can't write flash on new olimex lpc2148
(edited with more details)
I think my programmer or my dev board is broken.
The following is the contents of the flash script.
— begin —
halt
arm7_9 dcc_downloads enable
wait_halt
sleep 10
poll
mdh 0x0 100
flash probe 0
flash erase_sector 0 0 26
mdh 0x0 100
flash write_bank 0 main.bin 0x0
mdh 0x0 100
reset run
sleep 10
— end —
The following is the lpc2148.cfg file.
— begin —
telnet_port 4444
gdb_port 3333
interface “ft2232”
ft2232_device_desc “Olimex OpenOCD JTAG”
ft2232_layout “olimex-jtag”
ft2232_vid_pid 0x15BA 0x0003
jtag_speed 3
reset_config trst_and_srst srst_pulls_trst
jtag_device 4 0x1 0xf 0xe
daemon_startup reset
target arm7tdmi little run_and_init 0 arm7tdmi-s_r4
run_and_halt_time 0 30
target_script 0 reset oocd_flash_lpc2148.script
working_area 0 0x40000000 0x80000 nobackup
flash bank lpc2000 0x0 0x7D000 0 0 0 lpc2000_v2 14765 calc_checksum
— end —
When I call openocd:
openocd -f lpc2148.cfg
The following is a snippet of 1000 lines of output:
Open On-Chip Debugger 1.0 (today) svn:0.0001
$URL: svn://svn.berlios.de/openocd/trunk/src/openocd.c $
Info: jtag.c:1329 jtag_examine_chain(): JTAG device found: 0x4f1f0f0f (Manufacturer: 0x787, Part: 0xf1f0, Version: 0x4)
Warning: jtag.c:902 jtag_add_reset(): requested reset would assert trst
Warning: jtag.c:1157 jtag_check_value(): value captured during scan didn’t pass the requested check: captured: 0x0f check_value: 0x01 check_mask: 0x0f
Warning: jtag.c:1117 jtag_read_buffer(): in_handler reported a failed check
Info: target.c:240 target_init_handler(): executing reset script ‘oocd_flash_lpc2148.script’
Warning: arm7_9_common.c:972 arm7_9_halt(): target was already halted
Info: options.c:50 configuration_output_handler(): dcc downloads are enabled
User: target.c:784 target_arch_state(): target state: halted
User: armv4_5.c:340 armv4_5_arch_state(): target halted in Thumb state due to watchpoint, current mode: System
cpsr: 0xffffffff pc: 0xffffffef
I’ve tried flashmagic and phillips tool. The software cannot connect to the LPCboard via a serial connection. I am unable to establish a terminal connection to the device either.
I am assuming its dead. I’ve put an email into techsupport at sparkfun.
If your olimex lpc-p2148 is stuck…
I don’t think the board is operating as the schematic indicates. The 1,2 ISP switches do not do anything on my board. So, I had to physically make the jumps in pins myself. There was a problem with whatever was flashed in the device that was affecting jtag communications. I could not ever establish a clean connection. I was also unable to use flashmagic and lpc flash utility to flash the device via the serial connection. I suppose this is where the 1,2 ISP switches would come into play. But no combination of the physical switch settings or use of the DTR flag stuff in the applications would work.
Get a a jumper cable. Jump your BSL line to a nearby ground. Leave the 1,2 ISP switches in off position. Use flashmagic and it all works.
I did not go back and try the jtag flash mechanism, maybe later, it works with serial port and thats all I need to continue working.
flashmagic works everytime with the BSL jumper cable setup (on my windoze box - xp).
My primary dev machine is macbook pro. Here’s things I’ve noticed.
Do not use an un-powered usb hub with the arm-usb-ocd. It seems like the root of most of my issues.
If you get any error on the openocd call, don’t continue. It must establish a clean connection before trying any flashing or debugging.
