CC430Fx137 in a raw carrier mode
When using a CC430 series one could want to have an opportunity to measure a real carrier frequency, not calculated. So, there should be a continuous unmodulated mode. And to measure one should simply connect to a frequency counter.
If you try the SmartRF Studio (TI) you might find such mode there.
But is there a method to get such mode using some standard program pack or development library without writing an assembler code? The program which could be implemented into an autonomous equipment and run in the field.
Yourij
