Hello
I want to build a stable 10MHz signal source. The M9N specification sheet says that the maximum PPS output is 10 MHz (with a bit of jitter). I have several question if you can help me please:
Once the GPS is locked, is the 10 MHZ signal stable?
Looking at Example 23 Time Pulse Frequency it is not obvious that the PPS output can be set to 10 MHz
Looking at both ucenter and ucenter2 documentation, I did not see any reference to changing the PPS frequency
Should I pursue considering the NEO-M9N or is this not a good fit?
Thank you for your advice ![]()
