Changing scl/sda pins for qwiic-i2c to use ism330dhcx
I’m using the Sparkfun qwiic_ism330dhcx library from a pico w board.
I can access using GPIO 4/5 and all work well, but I want to change to 2/3, for use on a different board (Adafruit rp2040 datalogger), as there is where the connector socket is.
I cannot find where to change these addresses. Could someone help?
Managed to fix the issue. Paassed the pins in the init for class MicroPythonI2C in the micropython_i2c.py module.
Nice work!
