code for ITG-3200 WITH i2c
hi,
I find this I2C communication:
https://github.com/Seeed-Studio/LinkIt-ONE-IDE
I buy A ITG-3200 device and i want to connect it via rs232
someone know if i can find code to connect the device with rs232 and get the information from the gyro?
thanks
The product spec sheet :
https://www.sparkfun.com/datasheets/Sen … 0-01.4.pdf
says nothing about RS232. It seems to normally communicate via I2C.
You will need a microprocessor to read the gyro and send serial TTL data. You will also need a TTL to RS232 converter.
Hi
i buy this items:
Arduino Pro Mini 328
RS232-TTL CONVERTER
IMU Digital Combo Board - 6 Degrees of Freedom ITG3200
i need the code that i need to put on the ITG3200 and the code for the computer for read the data from the board
thanks
someone?
Look at
https://learn.sparkfun.com/tutorials/it … okup-guide
or do a Google search for itg-3200 arduino; there’s a lot out there to get you started.
/mike
ok thank i will search
i have another question
i want to write on CPP but in eclipse(ubuntu)
i need to find code for Arduino Pro Mini 328
and code for this IMU Digital Combo Board - 6 Degrees of Freedom ITG3200
I’m right? if yes how can i say the code from which port the arduino connect?
