Change the local altitude reference
BME280 Arduino and Teensy example
Marshall Taylor @ SparkFun Electronics
v1.1 by Nathan Seidle @ SparkFun Electronics
May 20, 2015
GitHub - sparkfun/SparkFun_BME280_Arduino_Library: An Arduino library to control the BME280 humidity and pressure sensor.
Feel like supporting our work? Buy a board from SparkFun!
https://www.sparkfun.com/products/14348 - Qwiic Combo Board
SparkFun Atmospheric Sensor Breakout - BME280 - SparkFun Electronics - BME280 Breakout Board
This sketch configures a BME280 to measure height changes, with a button
to zero the local relative altitude.
To use, run the sketch then press a button on the keyboard. The data on the
serial monitor will show zero. Then, move the sensor to a new altitude and watch
how the output changes!
Note: For most accurate results keep the sensor orientation and temperature the
same between measurements.
This code is released under the [MIT License](The MIT License – Open Source Initiative).
Please review the LICENSE.md file included with this example. If you have any questions
or concerns with licensing, please contact techsupport@sparkfun.com.
Distributed as-is; no warranty is given.
#include <Wire.h>
#include “SparkFunBME280.h”
BME280 mySensor;
#include “CircularBuffer.h”
//This is a fixed-size buffer used for averaging data, a software LP filter
//Depending on the settings, the response can be quite slow.
CircularBuffer myBuffer(50);
float localAltitude = 0;
void setup()
while(!Serial); //Wait for user to get terminal open
Serial.println(“Output a local changing altitude”);
Serial.println(“Press any key to zero local altitude”);
Wire.begin();
if (mySensor.beginI2C() == false) //Begin communication over I2C
Serial.println("The sensor did not respond. Please check wiring.");
while (1); //Freeze
//filter can be off or number of FIR coefficients to use:
// 0, filter off
// 1, coefficients = 2
// 2, coefficients = 4
// 3, coefficients = 8
// 4, coefficients = 16
mySensor.setFilter(4); //Lots of HW filter
//tempOverSample can be:
// 0, skipped
// 1 through 5, oversampling *1, *2, *4, *8, *16 respectively
mySensor.setTempOverSample(5); //Set oversample to 16
//pressOverSample can be:
// 0, skipped
mySensor.setPressureOverSample(5); //Set oversample to 16
//humidOverSample can be:
// 0, skipped
mySensor.setHumidityOverSample(0); //Turn off humidity sensing
//Assume the current reading is where we should start
localAltitude = mySensor.readFloatAltitudeFeet(); //Set reference altitude
for(int x = 0 ; x < 50 ; x++)
myBuffer.pushElement(0); //Clear buffer
void loop()
//Get the local temperature! Do this for calibration
mySensor.readTempC();
//Check to see if user pressed a button
if (Serial.available() == true)
Serial.read(); //Remove keypress from buffer
Serial.println("Local altitude reset");
float reading = mySensor.readFloatAltitudeFeet();
myBuffer.pushElement(reading - localAltitude);
float tempAlt = myBuffer.averageLast(15); //Do an average of the latest samples
Serial.print("Last sample: ");
Serial.print(reading, 2);
Serial.print(" ft");
Serial.print(" Last 15 samples averaged: ");
Serial.print(tempAlt);
Serial.println();
delay(200);
