Hello all, I´ve config the modul but he don’t connect to my adhoc network.
my config:
<2.19> Auto-Assoc roving1 chan=0 mode=NONE FAILED
factory RESERT
Set Factory Defaults
reboot
RebootWiFly Ver 2.19, 04-12-2010
MAC Addr=00:06:66:00:3d:8b
READY
CMD
set wlan auth <0>
AOK
set wlan channel <0>
AOK
set wlan join <1>
AOK
<2.19> set wlan hide <0>
AOK
<2.19> show net
SSid=roving1
Chan=0
Assoc=FAIL
Rate=3, 11Mb
Auth=FAIL
Mode=NONE
DHCP=FAIL
Boot=-1283303
Time=OK
Links=0
<2.19> scan
<2.19>
SCAN:Found 6
Num SSID Ch RSSI Sec MAC Address Suites
1 ucAir 01 -63 WPAv1 00:0e:d7:94:bc:a0 TKIPM-TKIP 3104 0
2 ucAirPublica 01 -64 WPAv1 00:0e:d7:94:bc:a1 TKIPM-TKIP 3104 0
3 eduroam 01 -63 WPAv1 00:0e:d7:94:bc:a2 TKIPM-TKIP 3104 0
4 ucaTS 01 -63 WPA_Mix 00:0e:d7:94:bc:a3 AES/TKIPM-TKIP 3104 0
5 SALA II 06 -57 WEP 00:0f:3d:39:3f:45 5100 0
6 moi 10 -52 Open 7a:b4:4a:bd:ce:e3 Adhoc 2200 0
join # 6
Auto-Assoc moi chan=10 mode=OPEN SCAN OK
ADhoc on moi chan=10
<2.19> Connected via Ad-Hoc on moi
DHCP: Start
show net
SSid=moi
Chan=10
Assoc=OK
Rate=12, 24Mb
Auth=FAIL
Mode=OPEN
DHCP=FAIL
Boot=-1283303
Time=OK
Links=0
<2.19> IF=UP
DHCP=ON
IP=169.254.140.61:2000
NM=255.255.0.0
GW=0.0.0.0
Listen on 2000
set wlan auth <6>
AOK
<2.19> show connection
8a30
<2.19> set wlan join <1>
AOK
<2.19> set w k 112233445566778899aabbccdd
AOK
<2.19> show net
SSid=moi
Chan=10
Assoc=OK
Rate=12, 24Mb
Auth=OK
Mode=OPEN
DHCP=OK,renew=-3
Boot=347608
Time=FAIL
Links=0
<2.19> get net
ERR: Bad Args
<2.19> show net
SSid=moi
Chan=10
Assoc=OK
Rate=12, 24Mb
Auth=OK
Mode=OPEN
DHCP=OK,renew=-3
Boot=347608
Time=FAIL
Links=0
<2.19> show rrsi
RSSI=(-48) dBm
<2.19> show stats
Conns=0, WRX=0/0, WTX=0/0, RTRY=0, RTRYfail=0
URX=6, UTX=3199, RXdrop=0, RXerr=0,
FlwSet=0, FlwClr=0
TX-UDP=0, evt=13, adhoc_lost=0
<2.19> show c
8a30
<2.19>
