If you wire one to the Due’s SDA/SCL/GND/PWR and then use a qwiic cable to interconnect the 2 kx134’s you could…the only thing is you need to cut the ADR left+center trace and solder the center+right ADR pads according to this https://learn.sparkfun.com/tutorials/tr … e-overview (go to ADR section)
Keep in mind once they are daisy-chained you’ll likely need to also disable one of the kx134’s i2c pull-up resistors by cutting the traces on ONE board
